Beiträge ausdrucken
:: Vorheriges Thema anzeigen
:: Nächstes Thema anzeigen
:: Ganz nach unten |
Autor |
Nachricht |
Henri
Anmeldungsdatum: 04.09.2017 Beiträge: 7 Wohnort: Hoeksche Waard, the Netherlands
Verfasst am: 05.04.20 23:15 Titel: RTM no 16 Backer & Rueb |
This is my first post on buntbahn. I apologize for not writing German, i can read it but writing it is very difficult.
From an old LGB Stainz I made a Backer & Rueb steam tram. It is the first ever locomotive I built. It is made of plasticard, mostly 2 mm for strength. The engine and drive gear are a ‘heuler’ (very old LGB), the chassis is also from the Stainz as is the boiler and chimney. The rest is made by myself.
I read this forum for a few years now and I am highly impressed by the master level of modeling I see here. No where my work matches what I see here but it is good to see what others are building to learn new things!
Nach oben |
4heiner Buntbahner
Anmeldungsdatum: 29.10.2005 Beiträge: 743 Wohnort: fonssilvana
Verfasst am: 06.04.20 20:50 Titel: Re: RTM no 16 Backer & Rueb |
Hallo Henri,
A very nice and clean work!
Did you have a drawing or is it a free-lance design?
Regards
Egidius _________________ Es ist nie zu spät für eine glückliche Kindheit! |
Nach oben |
Henri
Verfasst am: 06.04.20 21:12 Titel: Re: RTM no 16 Backer & Rueb |
Thank you!
It is built by the actual blueprints from the factory. |
Nach oben |
der koni Buntbahner
Anmeldungsdatum: 12.10.2008 Beiträge: 391 Wohnort: Münsterland
Verfasst am: 06.04.20 21:53 Titel: Re: RTM no 16 Backer & Rueb |
Hallo Henri!
Je hebt daar een mooi bakkertje gebouwd.
Ook de goederenwagens passen er goed bij
Groetjes
Manfred |
Nach oben |
Henri
Verfasst am: 06.04.20 22:15 Titel: Re: RTM no 16 Backer & Rueb |
Hallo Manfred,
Dankjewel! Is Nederlands ook toegestaan hier?
I’ll continue in English. Yes the wagons are RTM. The closed van was a LGB 4033 Chiquita wagon which I rebuild to this closed van. If interested I’ll post some pics of this rebuild?
The open wagons are subject to a future project, I want to remove the brake platforms as the RTM did not use brake platforms. |
Nach oben |
der koni Buntbahner
Verfasst am: 07.04.20 09:35 Titel: Re: RTM no 16 Backer & Rueb |
Hallo Henri!
Auch ein Beitrag in niederländischer Sprache dürfte für interessierte Leute kein Problem sein. Es gibt ja z.B. Google Translate.
Kennst du diese Buch?
Da findest du auf den Seiten 200 - 222 eine Menge ganz gut gemachter Skizzen im Maßstab 1 : 125 von Güterwagen der RTM.
Manfred |
Nach oben |
Henri
Verfasst am: 07.04.20 14:02 Titel: Re: RTM no 16 Backer & Rueb |
Ah, das geht zum 'Wunschliste'!
Ich suche nog ein paar Bucher from dieser Herr!
(See, BAD BAD BAD German! ) |
Nach oben |
der koni Buntbahner
Verfasst am: 07.04.20 16:44 Titel: Re: RTM no 16 Backer & Rueb |
Hey Henri!
Wenn Du viiiiiel Zeit hast, solltest Du mal diese Beiträge nachlesen.
http://www.buntbahn.de/modellbau/viewtopic.php?p=264883
Viel Spaß dabei!
Das Güterwagenbuch von A.Dijkers ist in den NL noch für unter 20,-E zu bekommen.
Schwieriger ist es da schon, diese Buch zu bekommen.
Auch da ist die RTM stark vertreten. Die Skizzen sind dort in 1 :100.
Manfred |
Nach oben |
Flachschieber Buntbahner
Anmeldungsdatum: 05.03.2003 Beiträge: 4189
Verfasst am: 07.04.20 21:59 Titel: Re: RTM no 16 Backer & Rueb |
als RTM Fan kann ich auch das Buch "De TRAM van Oud naar Goud" empfehlen.
Da sind sehr viele Zeichnungen drin. Ich habe mir das Buch letzten Sommer beim Besuch im Museumsshop vor Ort gekauft. Eine CD mit historischem Filmmaterial liegt ebenfalls bei. Das Buch ist auf Niederländisch. Auch wenn ich das nicht sprechen kann so kann man mit etwas technischem Verständnis den Sinn der Texte trotzdem gut erfassen.
Bild verlinkt von mixmediastore.com
@Henri:
Great Model
LG
Marco _________________
Mein YT-Kanal: https://www.youtube.com/channel/UCygNs7kZ3-UlkEJpF1gK2Bw?view_as=subscriber |
Nach oben |
